Old 03-27-2013, 08:26 PM   #125 (permalink)
turbovr41991
Civic CX/HX - '97 Honda Civic CX/HX
90 day: 63.77 mpg (US)
Originally Posted by California98Civic View Post
Have you had to make any adjustments to your odometer readings since adding the much taller VX tranny? I'm running the CX tranny (same gearing as the VX) with the DX ECU and gauge cluser and 14" wheels, and my distance readings are crazy under counts, if my measurements are correct. I calculated a 14% under count today! Can't be right. What's your experience?
Really? Which sending unit are you using? I am using the OEM 97 CX sending unit and mine seems to be nearly dead on. 14 inch tires with stock tires size as well. I have the HX cluster installed so I could have a tach, but that should not make any difference. Mine is within 1-2 miles of a GPS for distance traveled. I think I remember reading that the DX sedan transmissions were geared slightly worse than the hatchback, but I don't know if that would mean it would have a differen sending unit.
