Old 03-28-2013, 11:55 AM   #224 (permalink)
turbothrush
turbothrush's Avatar
2 x wrecked vx - '92 Honda Civic Vx
90 day: 62 mpg (US)
Rear spoiler / kamm looks great !
Thought I would mention what to expect for springback after glassing if there is some tension in the foam . Short answer is not much if you glass 1 side and let it cure . Next to none if you could glass both sides and let it cure before releasing the supports.
My roof was 2" thick ( no kerfs and pretty stiff ) and I was looking for about a 1" crown/camber over 8 feet. So I just guessed and forced in in 1 1/4 " crown with clamps and glassed 1 side . Springback was 1/4 " . Then I turned it over and forced it back to 1 1/4" and glassed the second side. Springback was 1/8 "
The Following User Says Thank You to turbothrush For This Useful Post:
a8ksh4 (03-28-2013)
