Ecomodder is one of the few place were such details creates the inspiration to sort such issues out. I think there are two high visibility facts
If you live in a city and your transport requirements are slight, an EV may ultimately prove the best solution. In the short term likely the cheapest too.
For those that dont, a hybrid offers load balancing between stop/start, and uphill/downhill, that provides the best compromise for the most efficient and therefore the next lowest cost option.
I guess the question there is, is an On/Off IC engine best like Prius, or a fulltime low power with load balancing battery better.
It would be nice to look at things logically in more modular terms,
- The search for the efficient electric drive
- The search for the efficient battery
and what is not necessarily a subset of both
- The search for the extended range solution
