Old 03-28-2013, 04:00 PM   #26 (permalink)
Shortie771
Eco Sol
Shortie771's Avatar
I found an interesting write-up HERE which seems to be a bit of work and take some welding experience, but I have to admit the final result is pretty amazing. Or you can go the easier and maybe cheaper way (which most, including myself will most likely take) by using pizza pans or coroplast.
Drill into your rims
Zip-ties
This seems like a simple solution
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
The Following User Says Thank You to Shortie771 For This Useful Post:
a8ksh4 (04-01-2013)
