Old 03-28-2013, 03:47 PM   #61 (permalink)
mozul
mozul's Avatar
Spitfire - '68 Triumph Spitfire Mk II
90 day: 26.18 mpg (US)
CivicHybrid - '04 Honda Civic Hybrid
90 day: 37.1 mpg (US)
Originally Posted by Shortie771 View Post
Is this switch for the injectors? Does it also kill your electronics? I don't want to have my stereo cut out every time I kill it.
This car is carbureted I don't have injectors. The kill switch connects to a relay that momentarily interrupts the power lead going to my coil, thereby cutting off the spark plugs.
The start side of the switch connects to a relay that temporarily connects the starter solenoid to +12V. The key switch would normally do this, but when it does, it also cuts power to my accessories (stereo), so I prefer this method of starting the car when I am doing EOC and can't bump.
The +12V source for the relays is only active when the key is on, so the switch is inactive when the key is not in the car.
The Following User Says Thank You to mozul For This Useful Post:
j12piprius (11-02-2014)
