Old 03-28-2013, 03:51 PM   #62 (permalink)
Shortie771
Eco Sol
Shortie771's Avatar
Originally Posted by mozul View Post
This car is carbureted I don't have injectors. The kill switch connects to a relay that momentarily interrupts the power lead going to my coil, thereby cutting off the spark plugs.
The start side of the switch connects to a relay that temporarily connects the starter solenoid to the battery. The key switch would normally do this, but when it does, it also cuts power to my accessories (stereo), so I prefer this method of starting the car when I am doing EOC and can't bump.
Thank you for the explanation. I can't believe it didn't even cross my mind to think if your car was fuel injected or carbureted.
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
