Old 03-28-2013, 04:49 PM   #27 (permalink)
RiderofBikes
Pantry Boy Supreme (pbs) - '04 Volvo S80 T6 Premier
ideas ideas
Originally Posted by Gealii View Post
i Wouldnt think you would need to attach it the overflowing air would keep it planted to the trunk except possibly on bumps but it would get pushed back down by the airflow
You wil most certainly need some sort retention setup, as if done with Coroplast(very light) will be lifted and overturned by a decent tail wind when your at a stand still. If it is done with light metals you might not need to in that case, a few earth magnets or bungies might help keep it in place for good measure.
Otherwise think about a LSR "drag" or Drift style wing extension more to clean up the rear. How does the rear of your car look underneath(get rid of your parachute).
Upper grill block
Belly pans help regardless. Make access holes for easy maintenance(its not hard). keeps chassis and engine bay clean if done right.
Diffuser with shallow angle of attack
Side skirts/wheel spats
Wing/Tail extension
Splitters are good for easy downforce and traction(increasing RR), not for FE without extensive tests
With the Stang platform, they're just about any number of bolt-ons for your needs
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
