Old 03-29-2013, 01:24 AM   #116 (permalink)
stiletto2
Originally Posted by GreenHornet View Post
Hey bschloop,
I think the best would be a single rear wheel drive from an ICE with an electric motor up front powering those wheels. This would give you the potential for all wheel drive when needed or desired. This adds weight, cost and complexity but gives you some advantages in times when traction is needed during bad weather situations.
You eluded to the fact that often the driver determines the outcome and this is very true but there are times when even a good driver has no chance without the proper vehicle in a given situation.
Nice points bschloop,
GreenHornet
IMO Practicality wise, also having electric drive up front would certainly aid in pulling through in certain situations, but they would likely be so infrequent that carrying around all the extra weight, not to mention the added complexity of having it work harmoniously with the ICE driven part would seem to make it impractical. That is to say that you would be negating some of the performance/economy of the ICE and drive system alone.
You said yourself that even a good driver has no chance without the proper vehicle in a given situation. If you were to be in difficult driving conditions frequently, then it would seem to make sense to me to just use a purpose built vehicle.
For a three wheel, reverse trike setup, I think front wheel drive alone whether electric or ICE would be better for pulling through hairy situations and not loose much in the way of performance/economy overall, though a single rear drive would likely be more efficient.
A hybrid such as you describe still might be able to be done I suppose, but it would almost surely be a tricky* bit to get such a system together and trickier** yet to have it be more economical and efficient in a substantive way. Otherwise, what would be the point of it?
Just sayin.
* tricky = onerously difficult and expensive
** trickier = even more so as above
