Originally Posted by Phantom
To fix the sagging and some weight with the what you have I would trim a coat hanger and coat it in glue then push it through the coroplast.
That is a
great idea! Why didn't I think of that?? I will work on that today. I have plenty of fiberglass resin, so I will just dip the rear hangers in that. I will put 2-3 coats on which should give enough stability to the hanger to keep it from bending. Thanks for the suggestion
