Old 03-31-2013, 12:40 AM   #19 (permalink)
88FieroGT
I havent gotten other sized parts that I need to make the two cylinder design work , because the shafts are spaced too far apart to work the way I had planned..
Havent had time , but just need to get it setup good enough in a "block" to hold the shafts still during operation and the rough design is good to go.
The other design of the flat 4 however are spaced how I originally set them up to be and even without a block producing the rotation how I want with the one way clutches engaging and disengaging how I want. So the 2 cylinder design will work exactly the same way except for parts not being optimal sizing.
