Originally Posted by mikeyjd
yeah for sure. im going with 60psi in my tires. if this set wears unevevly ill probably go 50 in the future.
You won't get uneven wear, if the results of hypermilers are any indication. The steel belt of the RE92 is quite stiff and stable. Insights have a slight tendency to uneven wear at any pressure, so rotate regularly.
