Old 03-31-2013, 10:15 PM   #5 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by teknicalissue View Post
How much temperature increase would determine MPG gains?
Most guys on here will report goals of 120s (min) to 140s (max) IAT for fuel economy. That's what I seek.
Also.. I was under the impression that free flowing intakes help better for gas mileage.. something about less work for the engine to take in air. is this false?
Free flowing intakes will only help if you are at WOT because anything less than wide open throttle will mean restriction from the throttle plate itself. And when you are driving for fuel economy, you are never even close to WOT, so the throttle plate is always offering restriction. Bewing at WOT... not good for FE
also reading another forum, this an Intake also helps out lean the engine out at highway speeds which is benefitial for me (90% highway travel)
It's not going to lean the AFR, because the ECU will rebalance the AFR according to its map. What will probably happen is the throttle will have to be open further, because hotter air is less dense and so to get the volume you wil need you will open the throttle wider. Opening the throttle more will mean less in "pumping losses," which means you'll waste less energy using the pistons to pull air past a mostly closed throttle plate.
Hope that helps... keep us posted.
