Old 04-02-2013, 05:28 AM   #16 (permalink)
nackerton
Originally Posted by oldtamiyaphile View Post
I bought 2x 4S3P batteries off eBay. The two will be wired in parallel for a 4S6P pack, plus side being that one pack can be removed for cycling/ balancing without 'disconnecting' the battery. The 6P pack should be enough for summer driving, but a third pack (for 9P total) could be added for total security in winter. Cost $240 and save around 16kg. If the car wasn't under warranty I'd be able to go a bit further by removing the stock battery connectors, steel battery tray etc.
Ok, but be careful with them. I had 4S1P pack in my cordless drill (szohmygod@ebay). It worked fine for ~20 charging cycles, but then went out of balance or something and broke down with wenting gas out while on charger.
