Originally Posted by trooper Tdiesel
ive got the split port SOHC it has a max tourque of 3,750 where the Zetecs have it at 4,500
thus the SPIs have a deeper geard set up.
final is 3.61 or 3.85?
O\D is about 25%
its a IB5 trans thats with the spi, but i don't think it would bolt up to a Zetec
keep on the look out for a under drive pulley, the common one is for the crank. but there's also a alt and water pump one.
new there rather spend-y so keep on the look out for used ones.
The SOHC has the 3.61. The Zetec uses the MTX75 with 3.85 FD.
