Old 04-04-2013, 09:24 AM   #230 (permalink)
Varn
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
I would lay up the composite on the bias. It will go over the corners a lot better. Use some super 77 spray to glue it down then use a paint brush for the epoxy. Cover any areas with seams with a strip of polyester cloth as a peel ply to keep it flat and to make it easy to do a secondary layer. You will want the edges to probably have more cloth (fiberglass) on them than the middle of the panels.
Noah Webster, 1787
