Old 04-06-2013, 02:02 AM   #1 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
Why less cylinders?
So it seems the general consensus is to use an engine with less cylinders. This makes sense as using less cylinders means using less gas. My question is why not use more cylinders that are smaller. So for example,
2 Engines, each 1.8 liters:
- Engine 1: 4 cylinder engine (.45 liters per cylinder) (ex. 79x91.5 borexstroke)
- Engine 2: 8 cylinder engine (.225 liters per cylinder) (ex. 39.5x45.75 borexstroke)
In the end, you still have the same size engine, just the bore and stroke is exactly 1/2 the size of Engine 1 with half the cylinders, but double the size cylinder. I'm thinking this might be more efficient as more cylinders will fire per revolution of the crankshaft.
Any thoughts?
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
