Old 04-07-2013, 06:56 PM   #16 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
Originally Posted by baldlobo View Post
any 4 cylinder over 2l creates a secondary harmonic, that can distroy engines; harmonic balancers are needed along with heavier crankshafts.
where as the 6 cylinder needs none of that.
gm engines
2.5l I4 110hp; 2.5l v6 145hp; 2.5l I6 154hp
195ci pontiac I4 vs buick 3.0l v6
Can you explain further the secondary harmonic issue?
Also, on the GM engines, how does the 2.5l V6 and I6 get better HP? That is what I was trying to get at with the original question.
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
