Old 04-09-2013, 01:57 PM   #32 (permalink)
3-Wheeler
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Originally Posted by skyl4rk View Post
*checks for tail*
I, too, am troubled by my lack of a tail.
I know I am buffeting my way through the atmosphere when I could be slicing through it. I could be saving at least 10% in fuel with a proper trailing edge. I could be passing through the dense fog with far less disturbance to the universe, yet still get where I am going quickly.
I may join thee in this quest for a proper termination of the vehicle body.
Hi,
Actually I think your savings would be way higher than 10%.
The "closing edges" of the Insight are way smaller than the typical car already, so comparatively speaking, the Insight has less of a gain by adding the tail.
A typical vehicle however, has more of a "square back-end" which means the addition of a tail has a much greater energy recovery based on the larger closing area before the tail is added.
If one happened to drive on the freeway a lot, then of course the gas savings are even higher based on the higher air speed.
Jim.
The Following User Says Thank You to 3-Wheeler For This Useful Post:
ECONORAM (05-02-2013)
