Old 04-10-2013, 04:30 PM   #7 (permalink)
RiderofBikes
Pantry Boy Supreme (pbs) - '04 Volvo S80 T6 Premier
That looks great! So, looks like you have about 3" ground clearance from the new dam? When you add your tire spats, try to stay around the same clearance as well unless you like the sound of scraping constantly... I do alot of driveway, parking lot entrances and speed bumps, maybe your cituation is different?
I dig the Lower block, I may be rethinking my adjustable one on mine atm! this looks much easier to work with
Staying tuned
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
