Old 04-10-2013, 07:20 PM   #9 (permalink)
RiderofBikes
Pantry Boy Supreme (pbs) - '04 Volvo S80 T6 Premier
Originally Posted by wungun View Post
The dam is located far back from the front lip of the car, so curbs and such shouldn't be too much of an issue. It's almost inline with the front wheels.
You will still rub at semi steep angles, as my dam has 3" across the entire front.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
