Old 04-11-2013, 04:00 PM   #19 (permalink)
cRiPpLe_rOoStEr
Originally Posted by mikeyjd View Post
How much of a difference would the axle swap make and how hard is the 3.9bt swap with an 88sr5 with a 3.0 currently in it.
The axle swap is more focused on dependability and resistence to the heavier weight of a 4BT. A 4BT swap is not so much harder than a small-block Chevy swap, unless for the weight. I could suggest you to get some lighter engine, such as the Kubota V2203-DI, which has been successful in many light truck Diesel swaps.
mikeyjd (04-11-2013)
