Old 04-11-2013, 04:31 PM   #453 (permalink)
NeilBlanchard
I made some new smooth wheel covers, because two of the pizza pan ones have come flying off... So, I bought some more cheap plastic aftermarket covers (from K-Mart) - a set of 4 is about $22, but I now use two of the spring wires per cover, so you only can use two.
I then stretched cloth over the front, and painted on glue, and then sprayed them black. This one is very similar to what I did:
http://ecomodder.com/forum/showthrea...ess-19109.html
The only difference is I used waterproof wood glue, which doesn't smell and cleans up with water (before it dries).
Here's another: http://ecomodder.com/forum/showthrea...ers-18495.html
And another: http://ecomodder.com/forum/showthrea...vex-14958.html
