Originally Posted by cRiPpLe_rOoStEr
In many situations, either some knobby tyres or a differential lock could deal with. Other folks often work around the e-brake to get individual secondary levers for each rear wheel, which ends up acting nearly the same way as a limited-slip differential.
I don't think so. The problem with washboards is that the tires are effectively in the air much of the time, so no traction. Plus they speed up a bit, and when they come down are moving a bit faster than they should be, so they spin. With 4WD, the front and back axles aren't likely to be airborne simultaneously, which keeps everything under control.
Then there's the fact that I can just buy a 4WD truck and not spend time messing with mods that may or may not work. And I get a low range to boot. Put knobby tires on it and there goes my highway mpg...
