Code suggestion:
Unless there is a reason not to, I recommend moving the code:
Code:
#ifdef debuguino
Serial.begin(9600);
#endif
as the first code executed in the setup() function. In v.63, it's run as the 14 statement in the function.
During my testing I needed to know that my device was running immediately, so I made it the first thing that runs.
On a side note, many, many posts back I offered a suggestion that eliminating the C++ portions of the code may contribute to a smaller compiled size. Well, I did a rewrite, eliminating all the object code (using structs and functions) and found that the compiler does a good job of simplifying the code - my code was within a few bytes! So, nothing saved.
I did encounter an issue in that the arduino v0011a software has no obvious provisions (that I could find) for sending extra parameters (ie switches) to the compiler. I found that out when I was trying to code a try...catch block while debugging, the exceptions code is not enabled by default and must include a compiler switch to activate. Assuming the developers have sent all the relevant optimization parameters, adding more parameters may lead to a bloat of the compiled objects.
