Old 04-14-2013, 09:48 AM   #2 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
You might cause excessive wear to the pump and I'm guessing it will be very hard to restart after running the pump dry. Ideally you'd convert the existing shutoff to only draw those 2 amps to shut the engine down. Or convert it to a mechanical shutoff. Less ideal would be to cut off the air going into the engine to shut it down. Just be sure whatever you use can't get sucked into the engine!
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
