Old 04-14-2013, 02:29 PM   #3 (permalink)
Fionn
Cheers GF, yes, I was worried about lack of lubrication in the early stages of the pump which was why I asked the question.
As you say reversing the solenoid would be the simplest solution, unfortunately the solenoid only has a single wire positive connection and uses it's outer threads as ground which makes this difficult.
I might buy a replacement solenoid and try to modify it internally to reverse it's action.
