Old 04-14-2013, 05:03 PM   #7 (permalink)
Fionn
I will try it without the plunger to see if it shuts off anyway (IP has some measure of electronic controls), I suspect it might in which case I can just run it that way.
I could add a normally open solenoid valve to the input of the pump for emergency shut off or even a manual valve perhaps as it would be unlikely to ever be needed.
