Old 04-14-2013, 04:47 PM   #3 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by some_other_dave View Post
I got irritated enough at not having room enough to swing my hammer that I unbolted the linkage at the other end and took it out with the transmission.
Pounding the pin out with the transmission on the bench was a whole lot easier. (I was actually swapping out the transmission at the time.)
-soD
Haha! Excellent. But if you were just replacing the oil seal on the shifter linkage, you would still need to remove the spring pin while under the car. BTW, how much work is involved in removing the other end of the shifter linkage? Special tools or just a wrench?
