Old 06-20-2008, 11:52 AM   #1 (permalink)
rocket
POS - '97 Ford Aspire
90 day: 47 mpg (US)
Exclamation Oil heat question
I live in rural CT and the only options for home heat are oil, electric, and propane. the most cost effective currently is oil (which my house is set up for). My furnace also heats my hot water. It has a fairly small resivor, but can heat water as fast as i use it (two showers going at once, only prob is low water pressure from the well tank). My big concern is that the furnace keeps the water hot like a standard water heater; cycling on/off throughout the day, regardles of use.
Anyone know of a way to minimize/eliminate the cycling? w/ my locked in rate of over $4/gal, my budget plan doubled from last year. I want to reduce the amount of oil i use to save money. (in the winter, i use programable thermostats: 54F during day, 65F when home (morn/even), 50F while sleeping. The house is new (2003) and well insulated, so i rarely see the temp reach the low settings.
Thanks!!
