I guess it's not that big a deal to do here, as you input the distance travelled instead of the odometer reading. Capturing the correction factor in the notes seems easy enough.
I have an app on my iPhone called "Fuel Log" that I use at the pump while filling, and I also use the Fuelly page, both of which are set up to capture your odometer reading. I know I have the choice with the app to configure it the other way (distance travelled on tank), but I made the mistake of setting it up the odometer way as it was a brand new car. I'll have to look into the Fuelly page and see if I can change it.
2016 BMW 535d
4100lb XDrive Eco-Yacht
