Old 04-17-2013, 01:29 PM   #31 (permalink)
darcane
darcane's Avatar
Check out the Ultragauge because it's cheaper and fully featured. The advantage is the many gauges your car does not have. For instance, I use the engine coolant temperature gauge to make sure my grill blocking is not overheating the engine. There is an alarm that goes off if a temperature threshold is exceeded. It can also display OBD2 trouble codes so that you don't have to take your car into a shop to see why the check engine light came on.
If your truck has a distance to empty gauge, I guarantee it is way off. The Ultragauge can be calibrated to be very precise. There are so many other features that you are better off reading them from the scangauge and ultragauge websites.
+1
Another feature I've unfortunately been making use of recently is that it will warn you about, display, and reset trouble codes, including pending trouble codes. Considering an Ultragauge costs less than the code readers at my local auto parts store, this alone makes it worth the cost to me.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
