Old 04-18-2013, 10:05 AM   #6 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Originally Posted by Quezacotl View Post
Or get a cheap door-lock actuator instead
Hmmm...
A door lock actuator might work well with the output shaft coupled to a threaded rod as IsaacCarlson suggested. Normally the actuator throws its full length and then stops, but the threaded rod plus a momentary contact switch might give the control you need.
Coast long and prosper.
