Originally Posted by RobertISaar
use the sending unit that's intended for the car, otherwise you'll likely run into guage issues. GM changed a lot of stuff around in that era, resistance specs likely wouldn't match up.
Both cars are supposed to be 40-250 ohm, but the sunfire runs lower pressure and less volume, so I might swap anyway.
