Old 04-11-2013, 03:10 PM   #51 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
Things are progressing. I am going to use BOTH cv shafts from a 1994 grand am so I can use factory seals on the tranny. I need to move some things around in the shed to make more room and I am working on getting the fuel tank out of the olds today.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 04-17-2013, 10:13 PM   #52 (permalink)
Team Pontiac
I got the fuel tank out the other day and then was told that the sunfire pump should work for the 3800. I want to put the olds pump in the sunfire anyway, but I will have to do some checking to see if I can swap just the pump or if I will have to swap sending units as well.
I picked up my new axle shafts today. The scrap yard could not find any good ones. $130 for both sides is not as bad as it could have been. Now I need to get a trans filter and some fluid. The motor will get cleaned up as soon as I can get the wiring labeled and pulled out of the olds. I have half of the wiring out already, but I need to label what is out and then do the rest. A good portion of the wiring will be removed, since the sunfire only has half the electronics of the olds. I won't need the keyless entry wires/module, the window wires/module, or the door lock wires/module. I can get rid of a lot of the relays since they will be useless, and the whole harness can go on a diet. The VATS system will be removed and replaced with a small chip.
1991 F-250:
Old 04-18-2013, 06:55 AM   #53 (permalink)
RobertISaar's Avatar
MC SBX - '95 Chevrolet Monte Carlo LS
Last 3: 29.75 mpg (US)
use the sending unit that's intended for the car, otherwise you'll likely run into guage issues. GM changed a lot of stuff around in that era, resistance specs likely wouldn't match up.
Old 04-18-2013, 11:48 AM   #54 (permalink)
Team Pontiac
Both cars are supposed to be 40-250 ohm, but the sunfire runs lower pressure and less volume, so I might swap anyway.
1991 F-250:
Old 04-18-2013, 11:57 AM   #55 (permalink)
alldata shows the 02 sunfire as a 40-250, but the 96 88 as 0-90.
it's been wrong before, but it wouldn't hurt to throw a multimeter on it and verify.
Old 04-18-2013, 12:22 PM   #56 (permalink)
Got MPG?
The Car - '09 Toyota Corolla CE Enhanced
I have to say there are some dedicated people on this site when they have an idea....this seems like quite a project. Most people would have tried to find a way to shave 700lbs off the Olds...
2013 Honda Civic Si - 2.4L
OEM front to back belly pan from the factory.
Old 04-18-2013, 01:35 PM   #57 (permalink)
Team Pontiac
I will test it just to be sure. The sender from the olds is only a few years old, but I hate to swap them out if the sunfire pump will work. But then again, I don't know if the sunfire pump puts out enough fuel. GRRR
Just have to do a flow test on both and see what happens.
I don't see how anyone could shave 700 lbs off the olds without doing major surgery. It is rusted out anyway, so the sunfire is the better deal. I can't even pick the car up anymore because the jack goes right through the bottom. I tried picking it up by the hitch and it came off. WI does not need to use salt.
1991 F-250:
Old 04-18-2013, 06:48 PM   #58 (permalink)
Team Pontiac
Yup.....0-90, dang. But YAY! I guess it is a diamond in the rough. I now get (have) to use the better pump anyway.
Ok, so the pumps get swapped. Then I can make sure the inside of the tank is clean.
1991 F-250:
Old 04-24-2013, 06:49 PM   #59 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
What'd you do for wiring changes and ECM when you swapped this?
I don't believe I ever read about it.
Reason I ask is that I just picked up an S10 with TWO T5's behind a 2.2 that needs main bearings and for the cost of a rebuild, I can buy a low-mile 3800SC and have similar fuel economy and a metric buttload of extra power [to the tune of 290HP and 310tq].
I know additional wires need to be added for the SC engines [I think I know...] but I can handle that, it'd just be nice to have a starting point from someone else's swap so I'm not going in blind.
Old 04-24-2013, 08:07 PM   #60 (permalink)
Team Pontiac
I am still working on the swap. The wiring is coming along, but I am only working on it part time. The wiring should be pretty straight forward, but we will see for sure.
I don't know if the 3800 will bolt up to the t5. If it will, great, but You will need a custom flywheel, unless your 3800 is out of a manual car already. I think camaros used the 3800 and they were rwd, so you could look into that.
Maybe just use a camaro tranny or get the whole thing from a junk yard and drop it in to the truck.
1991 F-250:
