I will test it just to be sure. The sender from the olds is only a few years old, but I hate to swap them out if the sunfire pump will work. But then again, I don't know if the sunfire pump puts out enough fuel. GRRR
Just have to do a flow test on both and see what happens.
I don't see how anyone could shave 700 lbs off the olds without doing major surgery. It is rusted out anyway, so the sunfire is the better deal. I can't even pick the car up anymore because the jack goes right through the bottom. I tried picking it up by the hitch and it came off.
WI does not need to use salt.
