Your best bet is to look up the specs for your wheel and find a OEM wheel with a good design that will fit.
I assume you are looking for your '05 Kia Rio? It looks like it uses a 4 lug 100mm bolt center (aka 4x100) bolt pattern with a high offset. This bolt pattern is extremely common. Older Civics (~1980-2005 including Del Sol and CRX), most Saturns, most small Toyotas (Corolla, Echo, etc), and a TON of other cars.
You may run into an issue with some wheels fitting over the hub if the hub is large on the Kia (couldn't find anything on the hub diameter).
