Old 04-19-2013, 10:05 PM   #54 (permalink)
GreenHornet
GreenHornet's Avatar
Hey CR,
Yes that I think would be the best of both worlds to design it in the way the Volt is laid out. You need to electronically controlled clutches to achieve it and its most definitely possible however those clutches are not cheap and you would still need two electric motors so cost and complexity is much more but you would end up with a pretty sweet setup in the end.
