well a long time ago I did take out the egr valve. and cleaned the inside out the best I could. also cleaned out the intake area when I took the intake manifold off which was pretty gunky
I also sprayed carb cleaner thru the egr valve opening in the bottom as well. how firm is the lever of the egr valve supposed to be? on the bottom where the hole is and hard to explain and I don't have any pics cuz im not by it.
theres the vacuum control and the part next to it is the egr solenoid right? whatever it is theres a black round filter on top of that. take it off theres no vacuum. unplug the source to that no change or cel either
manual said something about a fuse or something. I called Honda and they said they thought it wud be a fuse too
