Old 04-22-2013, 11:51 AM   #66 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
tuft testing video
Well, after a good night's rest and a fresh look at the tuft testing results today, I've decided it's good enough as-is. I'm not going to change it.
EDIT: Neil, I might just test that wheel strake/boattail idea to reduce turbulence, too. If that doesn't help, when I make the permanent tail, I'll use a little less curvature in the sides, which will add about 20 cm / 4 in. to the width of the rear.
Tuft testing video: (used Youtube's "image stabilization" feature, which is fantastic! The raw video is pretty bumpy at times.)
Next task: A-B-A test and weather-proof it. Weigh it, measure it, to answer those inevitable questions.
The Following 15 Users Say Thank You to MetroMPG For This Useful Post:
ausias (05-08-2013), Cd (04-27-2013), COcyclist (04-22-2013), ECONORAM (05-02-2013), elhigh (04-22-2013), Flakbadger (04-27-2013), HydroJim (04-22-2013), HyperMileQC (04-22-2013), Jyden (04-22-2013), NeilBlanchard (04-22-2013), PaleMelanesian (04-22-2013), Piwoslaw (04-23-2013), Rokeby (04-22-2013), Smurf (04-24-2013), Vekke (04-28-2013)
