Thread: hello there.
Old 04-23-2013, 02:22 PM   #6 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
The shop probably won't pump nitrogen past the recommended OEM PSI amount for liability issues. If your shop is willing to do it, then you're lucky, especially if they don't charge to "top it off". Whenever I have my shop do any work, I ask them to fill it up and they do so with no problem, knowing I've already payed for the nitro. If your shop won't do it and you want to go any higher than recommended PSI, you are going to have to do it yourself, which probably means using air, unless you have access to a nitrogen tank.
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
