Old 04-23-2013, 04:48 PM   #85 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Hi, Pascal: test route is straight, level and 1.6 km/1 mile "at speed" (not counting the distance used to get up to speed & level off, coast down and turn around etc). You can see the section of road I use here: along the shore of the mighty and lovely St Lawrence River, immediately to the southwest of where that map link is centered.
I plan to tuft test the bottom of the tail. The car needs a full belly pan for the bottom of the tail to work well. I'm sure it's in very turbulent flow now, but a full undertray will feed it some cleaner flow to work with. It's on the list!
