Originally Posted by Phantom
One thing you should check is how the grill works with the fans running at full speed. You do not want to be stuck in 5mph traffic then have the fans turn on pulling the grill shut.
I put a jumper on the fan control switch to turn it on and it does not effect the opening/closing of the grill block at all
Thanks for the suggestion, it would be pretty bad to be in bumper to bumper traffic and have my fans kick on and only make things worse.
