Old 04-24-2013, 01:13 PM   #23 (permalink)
razor02097
razor02097's Avatar
Tetanus - '95 Geo Tracker 4WD Base
90 day: 29.43 mpg (US)
300 - '82 Suzuki GS300 L
Last 3: 60.78 mpg (US)
Jeep - '98 Jeep XJ Cherokee Limited
90 day: 12.82 mpg (US)
On the road to get to the sidewalk I travel at top speed which is about 25MPH with bursts of furious pedaling to get up to 30MPH. The road is a 2 lane 35MPH road which has no shoulder and some blind corners. I hope cars flying up behind me will be able to react appropriately if I am traveling close to their speed.
According to the watts up meter I use 1.3 amps each way to get to the sidewalk. So far I can squeeze about 8 amps from the pack before the speed controller refuses to send power to the motor.
I did swap tires to ones that hold higher pressure and are a smoother tread. There is a little dirt so I don't want completely smooth tires.
On a side note this NiMH battery pack weighs 13 lbs. If I decide to upgrade my battery I can always make a 12V 40AH battery that would weigh the same. I could stick a small inverter on it and have a portable 110V power station.
Project Avalon: E bike build
