Originally Posted by cRiPpLe_rOoStEr
Which car is that? BTW oil injection is often quoted to be more efficient in oil consumption because it runs a lower amount of oil at higher RPM than it would be with pre-mix, which also helps to decrease the smoke.
Subaru 360 smokes during start then goes clean after it heats, If I rev it up @wot (possibly more than it should be as its a low RPM 2 cycle) it smokes a lot
So long as I am not near redline I do not note the car smoking excessively during my normal runs even at wot.
Cheers
Ryan
