Old 04-25-2013, 08:50 PM   #21 (permalink)
Originally Posted by rmay635703 View Post
NoX and rings are the only 2 reasons automakers did not choose that tech, eliminate NOx worries and ring issues might be possible to overcome.
Not so, at least from my understanding of how 2-cycle engines work. First, on every stroke part of the incoming fuel/oil-air mixture is sucked right through the cylinder and out the exaust port. There's a major source of unburned hydrocarbons, and poor fuel efficiency.
Old 04-25-2013, 09:44 PM   #22 (permalink)
RobertISaar's Avatar
MC SBX - '95 Chevrolet Monte Carlo LS
Last 3: 29.75 mpg (US)
direct injection eliminates that though, since the injector can be commanded to only fire once the exhaust port has been covered.
Old 04-26-2013, 09:12 AM   #23 (permalink)
My car is oil injected, it doesn't matter what oil I use and it does not smoke once warm, unless I lean into the thing at redline RPMs
Which car is that? BTW oil injection is often quoted to be more efficient in oil consumption because it runs a lower amount of oil at higher RPM than it would be with pre-mix, which also helps to decrease the smoke.
Old 04-26-2013, 12:41 PM   #24 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Subaru 360 smokes during start then goes clean after it heats, If I rev it up @wot (possibly more than it should be as its a low RPM 2 cycle) it smokes a lot
So long as I am not near redline I do not note the car smoking excessively during my normal runs even at wot.
Cheers
Ryan
