Old 04-26-2013, 01:48 PM   #12 (permalink)
oil pan 4
Originally Posted by mikeyjd View Post
Any good advice for someone wanting to learn this kind of thing hands on?
Swapping the turbocharger is not as hard as you think. Most swaps should only require basic tools, as long as you don't try to put a holset HE351VE on there.
I would say go with an HE351CW or some type of HX40 with a T3 flange and 3'' exhaust out let (which most HX40 are anyways).
The problem with the HE351CW is that I think it might have a 3.5'' exhaust outlet on the back of the turbocharger.
If you want to use a turbo with a 3.5'' outlet talk to me first because I have the hard to find cummins 3.5'' to 4 inch elbow, a 3.5 down pipe flange, a 3.5'' V-band clamp and a 3.5'' v-band clamp adaptor.
