Yeah, T-45. I found one locally on CL for $350 with a bunch of stuff. But I'd rather get my other car up a running first before tackling a manual swap.
However, the engine block swap is on the list of things to do since the current motor is in a dismal state.
I think it may end up being a big PITA if i went for the OM617.
*Note- the OM617 rates at 180ft/lbs, nearly 100 ft/lbs less than a stock Panther*
-ryan s.
1997 Ford Crown Victoria HPP- "Tank of Justice III" 194k - 578.9 miles on ONE tank
2003 Mercury Marauder- 63k, not so fuel efficient; #1,548 of 11,052
2008 Lincoln Navigator L - 244k (don't ask about mpg)
