Originally Posted by type2teach
-what is the best way to test the POT?
-I also stuck a vmeter on the Pos and Neg cables at the motor and by hand moved the POT to see what voltage was going to motor, and the highest it ever got was around 11v. (I have a 120v pack).
-Why would it measure lots of V with the motor NOT hooked up and just a few with the motor hooked up?
Any thoughts?
TIA!
I doubt it's the pot based on your previous charts. The output from the controller indicate that the pot is working well.
Would you repeat the test with another volt meter on the controller input from the battery? It should read the same as your battery voltage, but I'm almost betting that it'll be really low like the motor voltage.
