Old 06-20-2008, 07:43 PM   #3 (permalink)
accordaffair
SeeOurWrecks - '91 Honda CRX Si
90 day: 35.59 mpg (US)
Accord_Inspire - '93 Honda Accord EX
90 day: 24.56 mpg (US)
all screens show nothing but zeroes, as if I never hooked them up
vss I tapped into pin b10 by the ecu, injector 1 I used a brown wire with I think red dots, pin A1. I plotted these pins using my helms repair manual. I'm almost 100% certain I'm using the correct pins, BUT I should be using the positive leads for both of these, correct?
As an aside, the power plug the guino comes with doesn't seem to do squat, I have to wire up to VIN and GROUND, on the board for it to work, does that sound right? I wired both at the same time, just to be sure
I'm using rj45 ports and a length of cat5 to run the signal from the ecu area to the guino
I'm off to work, I'll be back later tonight
