Old 04-27-2013, 07:11 AM   #33 (permalink)
sendler
sendler's Avatar
90 day: 105.14 mpg (US)
90 day: 60.68 mpg (US)
90 day: 38.51 mpg (US)
PCX153 - '13 Honda PCX150
90 day: 104.48 mpg (US)
90 day: 80.94 mpg (US)
90 day: 72.57 mpg (US)
The new Chevy Malibu has some sort of energy gain system for downhills - it sounds like a mild hybrid that uses the alternator to slow the car and charge the battery?
Mercedes has had lin bus controlled alternators for years. It trys to only charge the normal car battery when you are decelerating. I don't like it because the programming always leaves the battery at 80% to make sure there is "room" to add more if you do slow down. We have to use a 50 amp charger every time we have the key on/ engine off for diagnostics because the voltage of the 100 amp hour battery will drop to 11,5V immediately.
The Following User Says Thank You to sendler For This Useful Post:
NeilBlanchard (05-04-2013)
